1992 Blazer running issues
Old 10-20-2012, 03:52 PM
mlrs21cp's Avatar
mlrs21cp is on a distinguished road
Default 1992 Blazer running issues
If anyone can help me on this issue I would really appreciate it. I just purchased a 1992 for $600.00 its in pretty good shape, but the people I bought it from said that it will only go 15miles an hour. I looked and there is no catalyac converter on it so that can't be the issue. It is a W motor and it runs but no speed at all. The gas tank has been changed new fuel pump, new plugs and wires and even a different brain, still only 15 miles per hour. I know very little about the Vortec engine that is in it, so any information will be very helpful. Thanks Charlie
Old 10-20-2012, 05:12 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
check fuel pressure with a gauge. (dont eye it,these things are sensitive)
MUST be 60 psi+ at key on and stay above 55 for 10 min...
they are common for fuel issues.
Old 10-20-2012, 05:16 PM
mlrs21cp's Avatar
Thanks Chris, where do I d ths test at? Never messed with this engine?
Old 10-20-2012, 05:31 PM
chris015's Avatar
look behind the manifold (big white thing) on top of the engine. back right side. you'll see a black screw on cap. there is a "nipple" there to test fuel pressure. Go to autozone etc and they have a loan a tool program. its basically a free tool thing. you do have a to leave a 100% refundable deposit (of retail value of the item) incase you dont return it. Once you have it,check the pressure. hook the gauge up. turn the key on. look at the gauge. It HAS to hit at least 60 psi at key on. If it does cool. let it sit for 10 min or so. if it drops below 55ish you have either a bad spider,or a bad valve in the pump. If it holds good,the fuel system is fine. that is if it pings above 60.
Once fuel system passes,move onto ignition. is the service engine light on?
Old 10-21-2012, 10:54 AM
mlrs21cp's Avatar
Update truck runs but real rough, and there is fuel in the oil, not sure how long it has been like this. Going to change the oil an filter. Could the fuel injection system be dumping fuel into the oil? Bad injector system?
Old 10-21-2012, 10:56 AM
mlrs21cp's Avatar
No engine service light on.
Old 10-21-2012, 11:31 AM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
Fuel in the oil usually is an indication of the spider assembly or fuel pressure regulator leaking. Looks like you will be taking the intake plenum off and checking for fuel washing on the intake.
Old 10-21-2012, 05:07 PM
mlrs21cp's Avatar
Thanks for the input, thats what I figured I would have to do.
Old 10-21-2012, 10:52 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
One more test that I would suggest out of experience is the so-called "nut kit." Inside the intake manifold there are two fuel lines going to the spider injector. They come from threaded fittings on the back of the manifold. When you take the top of the manifold off and expose the injectors turn the key on to energize the fuel pump and check to see if the two fuel lines in the manifold are leaking. That's a common source of leaks in these engines along with the nozzles and fuel pressure regulator.
Rhino
07-30-2011 05:47 AM
Pruney81
07-13-2011 12:36 PM
riel Veil
07-16-2010 10:47 AM
LWegner
13
06-25-2009 06:23 PM
Kojak
02-03-2008 03:37 AM
Quick Reply: 1992 Blazer running issues
