1994 S10 Blazer 4.3L(Black smoke, rough idle, floods right away...?
Old 10-26-2007, 03:01 PM
CrashPro993's Avatar
CrashPro993 is an unknown quantity at this point
Default 1994 S10 Blazer 4.3L(Black smoke, rough idle, floods right away...?
Sorry to hassle you guys but I have an issue that is frustrating me to know end... Recently Purchased a 1994 S10 Blazer(Tahoe Package) 4WD with 4.3L Vortec.
It runs very rought at idle and smooths out in the higher RPM range.
Shoots black smoke out the exhaust constantlyand leaves the grass on the ground black.
Strong fuel smell
Have to hold gas pedal all the way down to even get it to start (when it decides to.)
Exhaust is very load at both front doors, possible exhaust donut gaskets blown?
What Ive done thus far:
Changed Spark plugs, old ones were black and smelt like fuel of course.
Disconnected O2 sensor to set computer to default.
Found Coolant temp sensor on pass. side of block broke and replaced it.
Disconnected battery for 15 min and reconnected, same problem
Any Help would be greatly appreciated.
Old 10-26-2007, 03:44 PM
Default RE: 1994 S10 Blazer 4.3L(Black smoke, rough idle, floods right away...?
Do you have a CPI motor (black plastic cover on top of the engine with orange VORTEC text) or the TBI motor (traditional round air cleaner on top of the motor)? I'm guessing CPI.
Start out by testing your fuel pressure. For the CPI, the fuel pressure should be 55-60psi with the key in the run position, engine off. After you turn the key off, the fuel pressure should not drop more than 10psi and should hold steady after the initial drop. If the fuel pressure drops down to nothing, you have an internal fuel leak. A new member recently went through this and posted some very good pictures of the actual problem, but I can't seem to find the post right now... Anyway, you can remove the plastic cover and then remove the round plastic device under the cover (the MTV valve) and have a peek down inside. If you see pooled fuel, you have an internal fuel leak. If you cannot get a good look through the hole, either use a mirror or remove the upper plenum. With the upper plenum off, you can pressurize the fuel system and really look for the leaks.
Old 10-26-2007, 04:08 PM
yeah its a CPI, Ill check that out tonight. So if theres and internal leak, what is it usually? Thanks for the help!
Old 10-26-2007, 08:30 PM
Usually on the CPI motor, it is a faulty FPR. From the sounds of it, you have an internal leak.
Old 11-05-2007, 09:40 AM
ordered and entire intake manifold with the the CPI unit, sensors, and all gaskets. Should have it this week and will be putting it on this weekend. Ill keep you updated, thanks again!
Old 11-08-2007, 04:32 PM
Found this post pertaining to my situation. Don't know the guys, but I'd like to thank them for the time and effor they put into it.
Thanks!
https://blazerforum.com/m_65358/tm.htm
Bake
13
01-20-2013 11:36 AM
prosnowsk8er
07-02-2012 01:49 PM
int3414
05-01-2012 04:28 AM
pacoton
11-08-2009 08:56 AM
disturbedgame
05-02-2007 09:18 PM
Quick Reply: 1994 S10 Blazer 4.3L(Black smoke, rough idle, floods right away...?
