1994 s10 blazer 4.3L (W type) ODB scanner
Old 06-11-2009, 02:31 PM
bobby.0761's Avatar
bobby.0761 is on a distinguished road
Default 1994 s10 blazer 4.3L (W type) ODB scanner
Hello i have a 1994 s10 blazer tahoe lt has a 4.3L engine (W in the vin).
I just had a shop replace the injectors (spyder) and fuel lines (800.00).
The service engine soon light keeps coming on. I can't afford to keep taking in so thought i'd buy a code scanner and see if i can do this myself.
Not sure which scanner to get OBD1 i believe but not sure.
It has a plug on right side of drivers side under the steering wheel.
The plug is 2 rows of 6 (12 pin in all).
What scanner do you suggest?
I'm looking at this one: Equus 3120 Innova Diagnostic Code Scanner
http://www.amazon.com/Equus-3120-Dia...4745305&sr=1-1
I also need the ODBII as my brother has a 2000 Ford truck (sorry) lol
Thanks
Bobby
Old 06-11-2009, 02:43 PM
rriddle3's Avatar
Your '94 is OBD I.
Old 06-11-2009, 05:13 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
And you don't need a scanner, just a paperclip. Jumper pin A to pin B (top right-hand pins) together, then turn on ignition switch (do not start the vehicle).
Start counting the flashes. It will repeat each code three times, then move to the next. First code will be 12 (flash pause flash-flash) and last code will also be 12.
Go here for more info...
http://www.troublecodes.net/GM/
Old 06-11-2009, 08:08 PM
Cheapest scan tool ever!!
Old 06-11-2009, 08:14 PM
Especially if it came home from work!
Old 06-12-2009, 08:16 AM
KKZWasson's Avatar
KKZWasson is on a distinguished road
The guy at auto zone said to do this and I didn't believe it. SO went to Advance and paid $30 pretty much giant book. Nice to have the book with the codes and such but BIG waste of $$.
Old 06-17-2009, 11:24 AM
bobby.0761's Avatar
thanks for the link to the codes
also thanks for the info on how to get the codes without a scanner.
bobby
Old 06-17-2009, 07:38 PM
bobby
You're welcome
96jimmyslt4x4
07-18-2011 10:08 PM
davidsv8mustang
12-08-2010 10:23 AM
Biohazed
04-04-2009 07:55 PM
stormshadow
02-16-2008 07:36 AM
jurtecho
05-31-2007 07:59 PM
Quick Reply: 1994 s10 blazer 4.3L (W type) ODB scanner
