1st gen/2nd gen part interchangability?
Old 11-22-2009, 01:06 PM
NC93BLAZERLT's Avatar
NC93BLAZERLT is an unknown quantity at this point
Default 1st gen/2nd gen part interchangability?
I hit a deer last night, and am in need of a cooling system, and vacuum actuator for my 4x4. Will these parts work for my 93 from a 95? Thanks for any responses.
Old 11-22-2009, 01:29 PM
neo71665's Avatar
Vac actuator yes, rad might with some work but its not a bolt in.
Old 11-22-2009, 01:36 PM
My rad doesn't bolt in either, but the supports, which are separate, do. I will make it work if I have to, my main concern was whether or not the oil lines, etc. would match up ok.
Old 11-22-2009, 11:21 PM
neo71665's Avatar
By not bolting in I was referring it won't simply fit without some kinda modification. First gen and 2nd gens have different core heights and widths. This means the tanks won't be the same so the rubber pads on the bottom will have to be moved. If I recall the 2nd gen uses a shorter height so the pads on top won't even touch.
As for the oil coolers about the only work I've done on that system is remove it cause its too leak prone.
Old 11-23-2009, 09:12 AM
I see, thanks.
Sisk
Lifting Tech
02-15-2010 07:11 PM
1994BlazerS10
11-10-2009 11:06 PM
old skool luvr
11-10-2009 09:20 PM
94blueknight
04-06-2008 08:34 PM
TripleBlackBlazer
04-03-2008 06:48 PM
Quick Reply: 1st gen/2nd gen part interchangability?
