88 blazer broke door handle
Old 01-05-2014, 03:44 PM
4uzindian's Avatar
4uzindian is on a distinguished road
Default 88 blazer broke door handle
passengerside door handle is not broke .but the lever to the linkage is broke.hpoe you know what i mean any videos of this replacement availeble ? the inside door handle works.
Old 01-05-2014, 05:19 PM
mr.vls's Avatar
mr.vls will become famous soon enough
No Video but you will need do remove the door panel, Two nuts will hold the door handle on. There is a linkage from the door handle to the lock assembly. There should be two access holes to access the nuts. Most likely your door handle will need to be replaced. (They brake and are not repairable) Help mate makes replacement door handles.
Old 01-05-2014, 05:34 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
Its super simple, mr.vls covered it, Just pull off the door handle, There will be 2 self tapping nuts (so dont over tighten when installing)
To get the rod off the door handle, its just held in with a plastic clip. unlock the clip, lower it down and the rod will come right out.
I got mine from orielly for I believe 20 bucks.
Old 01-06-2014, 03:33 PM
4uzindian's Avatar
thanks so much for quick reply. i'm going to do this repair .il be closing this post as of now .
Sportblazer350
10-29-2013 11:11 PM
jayblazer
04-11-2011 12:44 PM
gla3dr
01-21-2010 06:44 PM
96BlazinLS
09-29-2009 03:17 PM
Jorgen
07-03-2007 12:38 PM
Quick Reply: 88 blazer broke door handle
