89 blazer rough running.
ok i got an 89 s10 blazer4.3 4x4 auto that runs rough and sometimes backfires through the intake. replaced the plugs wires caps and rotor button. also has a shifting problem shifts hard and sometimes slips between gears. it throw a code for rich exhaust one time and hasnt given it again. and it will clear up a little and then get bad again. any ideas would be great.
thanks alot
thanks alot
RE: 89 blazer rough running.
timing chain
they
thanks ill check it
You may want to also check for a vacuum leak at the base of the throttle body.
blazerguy22
11-14-2013 11:50 PM
ksimpson
14
10-07-2013 05:25 AM
93LT
03-11-2006 01:56 AM
