89 S10 4.3L - Beefier Radiator?
Old 08-22-2013, 03:53 PM
RomanKoch's Avatar
RomanKoch is on a distinguished road
Default 89 S10 4.3L - Beefier Radiator?
Hi there.
I noticed the other day that the radiator I have is cooling the engine/coolant, oil, and auto transmission fluid. Not sure if this is a stock setup, but I find that things get moderately warm under load.
Since I have about 250k miles, a radiator upgrade might be in order, but I'm not sure if there is a performance radiator for this model.
Would prefer something that's relatively 'bolt on' and doesn't require a bunch of rework.
Any ideas?
Thanks!
-Roman
Old 08-22-2013, 04:09 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Mine has all of that too. Its a factory thing. These rads work fine. Just replace it if you feel like it needs it. Only upgrade id give it is a better trans cooler.
Old 08-22-2013, 04:11 PM
newguy's Avatar
I removed my ac system. got rid of the ac rad. in front of the main radiator
Old 08-22-2013, 05:57 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
the factory cooling system is more than sufficient. Lots of radiators are setup this way, it will be ok
Old 08-22-2013, 08:58 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
If it struggles I would suggest a rad flush
Old 08-23-2013, 04:15 PM
ohsofly's Avatar
Yup, pour a bottle of CLR into that radiator, run it for half an hour, and flush it alll out. It will work good as new again.
David NM
11-01-2014 04:47 PM
GAseymourJR
11-04-2010 08:06 PM
bigdaddykane93
01-04-2010 12:03 PM
PawNtheSandman
05-02-2005 11:15 PM
93blazerman
Engine & Internal
04-07-2005 02:26 PM
Quick Reply: 89 S10 4.3L - Beefier Radiator?
