89 s10 blazer - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 04-28-2011, 12:38 PM
luvmaBLAZER is on a distinguished road
Cool 89 s10 blazer
hey there all well 1st of all im new to the site and now to the point i have an 89 s10 blazer with electric dash and the mph doesnt light up can anyone help please also at 85mph my engine shakes what can i do to my ecu to remove that or what can be done so i can go faster
Old 04-28-2011, 04:53 PM
nineTnine's Avatar
nineTnine is on a distinguished road
The digital dashes were known to fail so it could be that or a blown fuse. Possibly a loose connection in the back too. They are cool but pricey to fix/replace. I'll assume you have a 4.3L, they didn't have limiters so the ECM isn't causing the vibration. I had my old rust bucket S10 up to 90 once, it was loud as could be but no shakes from the drivetrain. Something may be amiss in the front end, bad alignment, loose tie rod, bad tire, ball joints going bad, it could be a lot of things.
Old 04-28-2011, 06:02 PM
wazzledoozle is on a distinguished road
Could be that your wheel bearings need some fresh grease too. But theres lots of things that can cause shaking at high speeds...
Old 04-30-2011, 11:57 AM
yeah man 4.3l and i luv it lol and well gona check it cause only my mph gauge doesnt light up and i really need it dont wana go too fast now or i might get a ticket
Old 04-30-2011, 08:25 PM
ohsofly's Avatar
I wouldnt want to go that fast in a blazer... Thats dangerous, these arent race cars man. If you want to go faster, try taller tires. My blazer runs out of ***** at about 70mph, so I dont think you are going to get it to go faster without a motor swap.
As for the speedo, mine flickers when I use the dimmer, so maybe play with the dimmer switch and see if that affects it.
If you want a new dash cluster, check this guy out. Some members have bought from him and nobody had a complaint. www.digitaldashsolutions.com
Old 04-30-2011, 08:54 PM
nineTnine's Avatar
The interstate speed limit here in Iowa is 70, so traffic is usually doing about 80 and my Blazer still has some go to it at those speeds, yours should be comparable I would think with the Vortec but how fast something is is comparable I guess. The TBI V6 luv has wouldn't hold a candle to either of ours I would hope though
Closed Thread
Thread Thread Starter Forum Replies Last Post
will 94 s10 blazer engine swap with 2001 s10 blazer 94BlazerGirl Engine & Transmission 1 08-28-2014 06:14 PM
S10 4x4 Blazer rearend vs. S10 2wd rearend Dallas1970 2nd Gen S-series (1995-2005) Tech 2 02-12-2014 11:19 AM
Panel replacement 2000 S10 Pickup to S10 Blazer rfine67 Paint, Body, & Interior 3 08-13-2011 01:04 PM
engine swap from 97 s10 blazer to 96 s10 ricky Engine & Transmission 1 07-22-2010 08:04 PM
Well i sold my 1994 S10, now looking for newer S10,any ideas?? 1994BlazerS10 The Lounge 5 03-03-2010 08:52 AM
Tags
1994, 4x4, 89, bearings, blazer, dash, ecu, location, newer, replace, rod, s10, s10blazerblazer, tahoe, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
