92 blazer bad bearing
Hi everyone,
I have a 92 blazer that had a bearing go out. So I am trying to pull out the engine but I am stuck on the fan. I can't seem to get it out. Is there a special trick to it? I have the radiator out already and I have been trying to get the 4 bolts around the shaft the fan off but they wont budge.
No special trick , try and stick a screwdriver between the bolt and the shaft , or put a wrench on one of the other nuts and go around and loosen all but that one .Good luck it shouldn't be to bad .
Camaro98
17
09-29-2011 02:01 PM
yazan84
03-10-2008 06:53 PM
