92 blazer oil line
Old 08-08-2014, 12:32 AM
Cidium's Avatar
Cidium is on a distinguished road
Default 92 blazer oil line
Not sure why but my oil line from the block to filter started to leak. I traced the leak to the upper hard line. I went to the local pick and pull for the new lines as a replacement part was priced at 100 bucks, pick and pull was 15 bucks. I pulled the lines from a 93 blazer, come to find out there is a difference between the 92 and 93 years. My 92 has O-rings on each line, where the 93 has a set of oil seals, both lines come as one seal. Never the less, this is dependent on the oil line, so the 93 lines worked on my 92. I made sure to use new oil seals for the 93 lines, they ran about 10 bucks.
this my 92 oil line using O-rings on each line
this is the 93 oil line using a "one piece oil seal"
This is the bolt holding the lines to the block, I found using 5 extensions, ( 2 short and 3 long) with a 13mm from the front of the engine is the best way to reach this bolt.
Attached Thumbnails 92 blazer oil line-92line.jpg   92 blazer oil line-93line.jpg   92 blazer oil line-boltin.jpg
Old 08-08-2014, 07:24 AM
BRYAN0010's Avatar
BRYAN0010 is on a distinguished road
I've replaced the oil cooler lines on my 1998 Blazer. I had to remove the bolt from the driver's side engine mount and slightly lift the engine to get it to clear. I got my replacement lines from PepBoys.
run_girl
04-02-2013 10:24 PM
chris015
04-08-2012 02:12 PM
rdhoping72
15
11-15-2011 03:54 PM
knightryderx2
03-08-2011 10:39 PM
todaresqSL2
11-10-2008 01:47 PM
Quick Reply: 92 blazer oil line
