93 Blazer will not start!
Old 01-14-2009, 12:17 PM
vortec 4.3's Avatar
vortec 4.3 is an unknown quantity at this point
Default 93 Blazer will not start!
I let my boss use my truck for about 5 mins yesterday. It started rite up when he left my work and drove down the street to pay a ticket. When he left the court house he said it started rite up for a bout 3 seconds and then just died. When i went up there to look at it i could not hear the the pump working. I changed that and i could now hear it pumping when i turned the key to prime the fuel lines. But i still cannot get it started. I have spark but cannot figure out why it is not starting. Any help would be appreciated!
Old 01-14-2009, 12:36 PM
rriddle3's Avatar
Default RE: 93 Blazer will not start!
See what happens when you let the boss use your truck? He did it on purpose!
Seriously, you need to run a fuel pressure test (detailed in many threads here) and let us know the results of that.
Old 01-14-2009, 05:48 PM
vortec 4.3's Avatar
I do not own a fuel pressure gauge to check for proper pressure but i did check the valve on the fuel line and the engine is getting fuel.
Old 01-14-2009, 06:14 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
but you need to know the EXACT amount of pressure as this is crucial. If you have good spark my bet is fuel related! Tell the boss you need a raise in order to fix his boo-boo! Just kidding! Jerry
Old 01-14-2009, 07:40 PM
rriddle3's Avatar
Like Jerry said, you have to do a correct fuel pressure test. The gauage can be found for ~$30. Fuel spraying from the testvalve doesn't mean a thing.
And why not ask for a raise?
Old 01-15-2009, 09:03 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
If you have a Harbor Freight near you, you can even get the fuel pressure tester for about $12....
Old 01-16-2009, 07:23 PM
vortec 4.3's Avatar
Itook it to the shop!I Gave up on it.
Old 01-17-2009, 01:18 PM
sdcrain is an unknown quantity at this point
i ve got a 2000 blazer doing the same thing it will start if i pour gas into the throttle body
Old 01-17-2009, 01:26 PM
Steve-a fuel pressure test is in order for you also! Jerry
stschuyler25
11-21-2010 09:34 AM
wayland
12-09-2009 12:38 PM
blazerJim1701
07-26-2009 09:18 PM
Larhatch60y
11-08-2007 01:05 AM
Quick Reply: 93 Blazer will not start!
