93 s10 blazer no 3rd or 4th gear - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 03-16-2012, 02:38 PM
gomfrddy is on a distinguished road
Default 93 s10 blazer no 3rd or 4th gear
hey fellas, gals...got a 93 auto 4x4 blazer won't go into 3rd or 4th any hope or it it time for r&r thanks in advance...o btw what tranny in this truck?
Old 03-16-2012, 11:40 PM
Toby Hanson will become famous soon enough
Since your truck is a 1993 it should have the 4L60E which is the electronically-controlled version of the good ol' THM 700R4. To be sure, check the stamping on the right side of the transmission case at the bellhousing. It should say M30. That should verify it.
Old 03-17-2012, 03:36 PM
ohsofly's Avatar
If there is wires plugging into the side of it, you have a 4L60E transmission. If there is no wire bundle, then its a 700R4 (doubtful that the previous owner swapped trannys)
Most tranny shops will let you cash and carry a rebuilt for $1000 cashola... Thats a good deal. You could try your luck with a junkyard trans but you might just get one thats no better than the one you are pulling.
If your fluid is burned smelling and very dark, then my first guess would be 3-4 clutch pack failure - requires a rebuild to repair.
Unplug your wire plug on the side of the transmission (or pull TRNS fuse), start the truck and put it in gear - can you drive it? I say this cause I think it starts out in 3rd gear by default when electrical connection is lost (which you force by unpluging or pulling the fuse). If you have no movement and it just revs up, then your clutches are toast and its time for the R+R. If it will drive, then your 3-4 servos are causing the problem, they are about 20 bucks and can be changed on the side of trans with it in the vehicle.
Go unplug that wire and report back to us with your findings.
Theres a few guys around here that know these trannys inside out, just give it a couple days and they will chime in with some help.
Old 03-28-2012, 06:27 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Is your speedometer working ? If its not then its the vehicle speed sensor .
Closed Thread
Thread Thread Starter Forum Replies Last Post
No 3rd or 4th gear pudgedawg007 Engine & Transmission 0 12-18-2012 01:51 AM
97 Blazer no 3rd or 4th gear greenhornet 2nd Gen S-series (1995-2005) Tech 4 04-28-2012 07:28 PM
96 Blazer no 3rd or 4th Lance Melin Engine & Transmission 1 04-09-2012 06:15 AM
94 blazer loses 3rd and 4th gear need help paul94blazer4x4 Engine & Transmission 0 07-11-2011 06:01 PM
Rebuilt trans now has no 3rd or 4th gear. 1blkblazer422 Engine & Transmission 16 05-03-2009 07:31 PM
Tags
1993, 2000, 2007, 2nd, 3rd, 4l60e, 4th, blazer, change, failing, gear, mo, s10, selector, shift, silverado, starts, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
