94 s10 blazer coolant temp guage - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 11-06-2011, 08:33 PM
drummerdude is on a distinguished road
Default 94 s10 blazer coolant temp guage
Alright so I need some help here. I have a coolant temp guage that does not work. I have done some research and searching and found out which sensor it is, and I have tested the guage itself and wiring by shorting the connection to ground and the guage works. I just went and replaced the temp sender unit and the gauge still does not work. Its about 50 degreees outside and I let the engine warm up for a good 20 mins and the gauge still has not moved, what eles can I check?
Thanks guys
Old 11-06-2011, 10:40 PM
mr.vls will become famous soon enough
Which sending unit did you replace? There are two temperature sending units, one is for the gauge and one is for the ECM. The one for the gauge is mounted on the side of the block. The one for the ECM is mounted by the water inlet at the intake manifold. Also there are two different temperature sending units for the dash. One is for vehicals with an idiot light and one is for vehicals with a gauge. I have had the parts store sell me the one for a car with an idiot light before.
Old 11-07-2011, 12:17 AM
pettyfog is a jewel in the roughpettyfog is a jewel in the roughpettyfog is a jewel in the rough
Quote:
Drummer.. that is very likely the problem.
Old 11-07-2011, 06:54 AM
I replaced the one on the side of the block. And it is the correct sensor, looks just like the old one, so now I'm going to play the game of track where the bad connection is.. IE ground, clip, etc.
Old 11-07-2011, 06:57 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
the trucks a 94....do you have the terrible digital dash? If so it could just be the cluster. They are notorious for loosing gauges.
Old 11-07-2011, 08:15 AM
harley745's Avatar
harley745 is an unknown quantity at this point
Default Temp Guage
I had the same problem, and finally added a Manuel temp gauge, now I know for sure what the temp is, also according to specs I added a 195 degree thermostat, now it runs between 190 and 195. The temp is never out of the range. Good Luck Sir
Old 11-07-2011, 08:55 AM
bromanjr is on a distinguished road
Quote:
Thanks guys
If shorting the wire to ground pegs the gauge, then it is the sending unit, you got the wrong one or a bad one.
Old 11-07-2011, 08:35 PM
I do not have the digital cluster. Can someone post the link for the right part at napa or autozone?
Closed Thread
Thread Thread Starter Forum Replies Last Post
temp guage 91 S10 4x4 travler 1st Gen S-series (1983-1994) Tech 2 01-10-2014 05:06 PM
Temp switch and/or Temp gauge sending unit and/or Temp sensor? "w" engine zakm0n Engine & Transmission 5 01-09-2011 08:31 PM
Temp guage randomly rises then drops pmezo 2nd Gen S-series (1995-2005) Tech 28 11-06-2010 05:30 PM
No temp reading on temp guage bertrenolds 1st Gen S-series (1983-1994) Tech 4 12-19-2008 08:45 PM
Coolant temp. guage not working myronhntr80 1st Gen S-series (1983-1994) Tech 7 03-06-2008 08:58 PM
Tags
1994, 94, blazer, coolant, forum, gauge, gen, ground, guage, problems, s10, temp, temperature, wiring, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
