94 s10 blazer fuel pressure valve - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 02-10-2010, 11:27 PM
hobbs2 is on a distinguished road
Question 94 s10 blazer fuel pressure valve
Help can any one tell me where the fuel pressure regulator valve is located at. Got It with bad vavle when I got it 02-09-10 Got it home tonight and off the rollback truck. I put new fuel filter on it with no help on 02-09-10?I think it is in front of pletum {intakemanifold}. What is the vavle on top in middle of pletum has wires to it. Thanks guys
Old 02-11-2010, 12:45 AM
Gimpy Blazer is on a distinguished road
I would really suggest you get a service manual of some kind for your truck. If you are going to crack into the fuel system like it looks you'll need it. If your engine is a Vortec (looks like it) the fuel pressure regulator is under the upper intake plenum. What exactly is wrong with your truck? Throwing parts at it (shotgun troubleshooting) might eventually fix it but finding out what's wrong and fixing that item is a lot easier on the wallet.
Old 02-11-2010, 06:04 AM
You can also search the forum. There is a lot of information about the CPI FPR around here. Including how to change it (tech article diy section).
Old 02-11-2010, 01:28 PM
ohsofly's Avatar
The FPR is under that thing you talk about with the wires on it... Go read the posts farther back as there is about 10 of us last month that had these problems to deal with... Do a forum search for "CPI vin W" and see what you find.
Closed Thread
Thread Thread Starter Forum Replies Last Post
1996 blazer no fuel pressure at schrader valve frabes Engine & Transmission 0 07-25-2014 05:42 PM
Fuel pressure test - Schrader valve size and fitting type dj00140 2nd Gen S-series (1995-2005) Tech 16 09-13-2011 06:47 PM
Fuel Pressure drops off, check valve or injectors cage47 2nd Gen S-series (1995-2005) Tech 5 09-29-2009 08:43 PM
fitting size of 93 Blazer CPI fuel pressure valve?? scottyk 1st Gen S-series (1983-1994) Tech 4 06-23-2007 04:13 PM
Fuel Pressure relief valve 2klt General Tech Help 3 04-15-2006 05:22 PM
Tags
10, 1995, 43, 94, blazer, chevy, fuel, located, plenum, pressure, regulator, s10, system, troubleshoot, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
