encoder problems
encoder problems
i have a 94 s-10 blazer and i am getting a code 2. i just need a diagram of the np233 encoder motor so i can tear it apart and put it back together. i'm not sure which terminals are which. can someone help me out?
tccm code 2 on obd1
i jumped the termenals and 4wd lights flashed code2, i know its the encoder but i want to see a breakdown for it before i take it apart
Check out the posts in the Tech Article (DIY) section. All of the codes for the NV233 transfer case are the same so you can either look at the post by error_401 or the one by lastcoupe.
Different system. This is a TCCM code, not an OBD code.
gusszgs
14
11-11-2009 01:00 PM
CaboKP
01-27-2007 03:44 PM
OldBlazer
01-10-2007 01:37 AM
