Bought a old 89 blazer idles then dies....HELP
Old 03-17-2009, 09:24 PM
muleman's Avatar
muleman is an unknown quantity at this point
Default Bought a old 89 blazer idles then dies....HELP
1989 4.3l 135,000 miles...
replaced dist.cap, rotor button, plugs, plug lines, coil, fuel filter
truck starts up idles real good for about a 3min then kills it self out.. i thought the CAT was plugged so chopped exhaust it was shot anyhow.. new exhaust to come.. still didnt fix..
any suggestions???
also when you drive down the road it runs bad at low rpms if you run it hard in 1st or 2nd gear with the rpms up runs alot better..... help me out
Old 03-18-2009, 07:04 AM
Sunshine Coaster's Avatar
Sunshine Coaster is an unknown quantity at this point
Sounds like it might be a fuel pressure problem...I'd check to see what the pumps putting out.
Old 03-18-2009, 07:47 AM
A vacuum leak can cause it to run poorly at low RPM. Check the throttle body base gasket for leaks.
Old 03-18-2009, 10:30 AM
muleman's Avatar
will check.. would a bad EGR valve show this kind of prob.. thanks..
Old 03-18-2009, 07:29 PM
muleman's Avatar
checked for leak under the TB none found... took off EGR and cleaned still running like crap... what would a bad ICM module do would it do something like this... its not showing any codes and check engine light not on but everytime i mess with it i unplug the battery so it wont go dead............. any help.............. kind of smells like it is running rich.....
tagodwin23
02-03-2013 12:39 PM
smitchelle
01-05-2012 11:24 PM
tinkstar1308
02-25-2011 03:43 PM
cfrain
12-09-2010 07:05 AM
blbikerood
01-19-2010 06:09 PM
Quick Reply: Bought a old 89 blazer idles then dies....HELP
