Chugging/Missing
Chugging/Missing
I have a 1991 blazer with the 6cyl engine, It has appeared to develope a chugging/missing near the drivers side when its ideling. Could this just be because of thesuper crappy exaust system on it? Im almost sure it has a leak. Also I just did a tune up and gave it new wires and plugs. Thanks for your help.
RE: Chugging/Missing
how did the spark plugs look? was the driver side fouled out? if so and ur getting other symptoms such as worse fuel milage and smell of sulfur (rotten eggs) from the tail pipe then it is probably an internal fuel leak in the plenum. its not that hard to remove the upper plenum and check.
I have also noticed a real lack in acceleration, prob.do to the exaust, The plugs look ok, Im gonna swap em out anyway, anything else I should change out the might help this problem? Thanks for your help!
you've got a 91, right? Eight digit of the vin z? If so, doubt that you've got a plenum issue as you haven't got one one that tbi engine. Fix exhaust-full tune-up, ie if not done-wires, fuel filter, air cleaner, good quality wire set, the plugs, cap and rotor and a pcv valve. Only gonna help-atleast gas mileage. JP
Yea its a 1991 s-10 style with the 6 cyl. gas mileage is gonne suck no matter what I do besause is has a 3in body lift and a 4in susp. lift that sits on 35 swampers. Thanks for your help though!
schnarr
08-25-2008 11:37 AM
