run high and low
Old 08-11-2009, 08:50 PM
al987's Avatar
al987 is on a distinguished road
Default run high and low
have 1990 4.3 4x4 s10 blazer start good and run for 30 sec then run high and low once warm up run high change fuel pump 3 week ago map and tps sensor
Old 08-29-2009, 09:55 PM
al987's Avatar
[quote=al987;238158]have 1990 4.3 4x4 s10 blazer haveing problem iding. wen cold run"s high and low. change fuel pump 4 week ago,a week later went bad put new one in change map&tps&iac sersor.start ok but idies erratically wen warm up ok but not geart.
Old 08-30-2009, 07:14 PM
elgringo's Avatar
elgringo is on a distinguished road
check air sensor? idle is a air fuel mixture.
why did the fuel pump go bad in one week? is this one on its way out the door too? not enough continuous power to run it?
Old 09-07-2009, 08:38 PM
al987's Avatar
Default the same thing
change the fuel pressure regulator.(sping was broke)but it run"s the same.
m3dragon
02-24-2015 10:04 AM
1998LT
04-01-2011 01:07 PM
LovemyBlazer95
07-24-2009 11:24 PM
DrEaMsTeVe
04-25-2009 02:52 PM
portcqb
10-05-2008 07:22 PM
Quick Reply: run high and low
