cruise control quit working
Old 06-07-2007, 03:01 PM
6wraith's Avatar
6wraith is an unknown quantity at this point
Default cruise control quit working
well ok another problem i have(oh yay). my cruise control just up an quit working. it seems that a different problem i had stopped an then this dont work. i had a tail lamp fuse keep blowing and when that stopped so did the cruise control. i really have no info on what to do. ive searched on here and found a few things. like a relay may be bad but where is that located? and ill probably buy a new switch that is with the brake switch. im hoping its not anything more then that. but does any one have other ideas that i would need to do and check? thanks for any help
Old 06-20-2007, 11:51 AM
Easy 8 is an unknown quantity at this point
Default RE: cruise control quit working
I replaced my module and servo, and was told that it is a electrical problem in my steering wheel (switch). I havent got to it yet as I don't have wheel puller. It sounds like you have a short, which would most likley be your switch.
Old 06-21-2007, 07:19 PM
xv75 is an unknown quantity at this point
93' caused me alot of headache and foun about six months later that the pin that holds the cable to the vacuum ball broke replaced and has worked fine for a couple of years now. This may not be your problem but it don't hurt to see.
Old 06-27-2007, 12:44 PM
nemesis_SS is an unknown quantity at this point
hmmm.....have you tried putting a brick on the gas pedal? Seems to have fixed my cruise.
gatorboy44
11-04-2011 10:35 AM
S10Frank
06-07-2011 06:12 AM
Steinbruchsoldat
12-18-2010 08:32 AM
walleye seeker
10-14-2010 06:52 AM
bobbye
01-02-2009 07:54 PM
Quick Reply: cruise control quit working
