Do all 4.3 cpi engines skip a little at idle?
I've had my 94 Jimmy for a while, chased down many issues since I bought it. Everything is working good. 18 mpg average. Good acceleration. But It has a skip that sounds like a puff of air from the tailpipe every 5-10 sec ONLY AFTER it warms up. Its done this since i've changed the dist, spider inj, egr clean and screen, even a new coil and plugs... Do they all just have this mild skip, it's really not noticeable. Most passengers never notice until I tell them to listen for it. The engine doesnt even visibly shake. So, does every 4.3 cpi engine have this little skip?
Uyp , throttle body! This is the one benefit of a throttle spacer. When I put a little higher speed stall converter the slight skip got worse. When I put the spacer under the throttle it got half way better. You might bump your throttle stop a LITTLE (use a dvm i forgot the voltage) and make sure your egr isnt leaking.
CPI= Central Port Injection.
MPFI= Multi Port Fuel Injection.
CPI has one injector that feeds the entire motor.
MPFI has an injector for every cylinder.
Someone please correct me if I am wrong.
i dont know about the EGR though. and last weekend i averaged right around 20mpg in mine. but that was mostly highway. i averaged 18 before that when i drove to about 150 on the highway, up and over the Grapevine (one of the big hills in southern cali), to Bakersfield. Launched a boat all weekend for the boat races and did a little bit of 4 wheeling.
K and N filter IMO isnt worth the money.
wicked. thanks!
so is the spider injector a multi-port? or is it a single center injector with 6 legs coming off of it for each cylinder?
k and n not worth it due to it not offering more air flow? or no more power than a generic filter? i'm curious simply for the mileage.
thanks again.
thanks again.
wicked. thanks!
thanks again.
thanks again.
50lb_cat
03-22-2012 07:20 AM
jasonblinn
01-26-2011 10:23 AM
