Driver Side Power Door Lock Problem
Old 04-07-2008, 05:27 PM
muszyngr's Avatar
muszyngr is an unknown quantity at this point
Default Driver Side Power Door Lock Problem
The driver side power door lock switch does not work however I can lock and unlock both doors from the passenger side. How can I test to see if it's the switch or is it some relay or fuse thingie?
Old 04-07-2008, 08:39 PM
Default RE: Driver Side Power Door Lock Problem
Definitely sounds like the switch is bad. All of the door locks are run off of the same fuse so it isn't that. You should be able to remove the switch and test it with a multimeter.
Old 04-08-2008, 01:24 PM
muszyngr's Avatar
Good tip, now since all I know about a multimeter is that you probobly get one at Radio Shack, and what I'm about to find out on Google as soon as I post this, LOL. Could you lemme know how to test the switch with a multimeter and what reading I am looking for. Pardon the ignorance, and thank you.
mamawolf70
04-10-2020 10:44 AM
rd-blazer
09-19-2011 02:14 PM
HigherPower
15
05-05-2011 11:25 PM
ussexplorer
04-04-2010 08:39 PM
bdubs
04-27-2009 05:11 PM
Quick Reply: Driver Side Power Door Lock Problem
