Drivers side power mirror. no side to side, is there a relay? or just the switch
Old 04-05-2011, 11:06 PM
jakegaisser's Avatar
jakegaisser is an unknown quantity at this point
Default Drivers side power mirror. no side to side, is there a relay? or just the switch
I have a parts jimmy and a nice 93 GMC S15 jimmy
My problem is my passenger side power mirror works completely up/down, left/right.
but then on the drivers side the power mirror will only go up/down.
The parts jimmy mirrors work completely. So I first changed out the mirror, and when that didnt fix anything I changed out the switch.
Still not fixed.... so now I can only assume there is a relay OR if there are no relays for the mirrors, then I must have a bad wire somewhere...
Anyone have any ideas?
Old 04-06-2011, 12:01 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Go to your local library. Find out if they have access to the Mitchell on-line repair manuals. If they do, get on the Mitchell website and look up the testing procedure for the power mirror circuit. It's very thorough. I used that testing procedure for the mirrors on my '94 Blazer.
Old 04-06-2011, 12:35 AM
killer thank you so much! I have already completely ruled out the mirror and the switch.
but im just not sure what that leaves... lol! I will check out the library in the next few days.
Old 04-06-2011, 04:50 AM
Magmotor's Avatar
Magmotor is on a distinguished road
There are no relays in this system. Locate the mirror connector (in the door) and check for power to the switch. Yellow & Green wire is the up & down. Blue & White are the right & left, you can trace from there.
Old 04-06-2011, 07:20 AM
As said, it is all wiring. Sounds like there is a break in the wiring for the driver side mirror.
Old 04-06-2011, 11:35 PM
thats what i was afraid of, doh! I will trace it down in the next couple days, thanks guys!
Radio
02-07-2018 03:29 AM
scphill34
03-10-2013 03:59 PM
pghblazer
12-19-2009 02:30 PM
danzy55
02-28-2009 12:36 PM
gmaltese
10-19-2006 11:30 AM
Quick Reply: Drivers side power mirror. no side to side, is there a relay? or just the switch
