ECM location - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 02-10-2006, 11:21 PM
redman is an unknown quantity at this point
Default ECM location
[:@] have a 1988 S10 Blazer and need help finding the ecm location. I checked behind the pass. kick panel and the glove box not there or I did not see it. all help will be welcomed.
Old 02-13-2006, 04:55 PM
Default RE: ECM location
Unless someone moved it, it should be behind the passengers side kick panel. SInce its not there, follow the wiring harness. Look for a big bundle of wires running inside the cab, usually on the passengers side of the firewall. Move the carpet out of the way on the passengers side to locate it. Follow them under the dash.
Closed Thread
Thread Thread Starter Forum Replies Last Post
ECM / PCM fuse location ??? 95 Blazer miztic2u 2nd Gen S-series (1995-2005) Tech 7 07-10-2012 06:37 PM
ECM / PCM fuse location ??? 95 Blazer miztic2u 2nd Gen S-series (1995-2005) Tech 0 07-08-2012 08:21 PM
Change 1996 ECM to 1998 ECM? roddy 2nd Gen S-series (1995-2005) Tech 1 06-28-2012 05:52 PM
ECM/CPI Question for 93 Blazer 4.3 Vortec. NC93BLAZERLT 1st Gen S-series (1983-1994) Tech 16 01-04-2010 12:08 PM
91 chevy blazer s10 ecm pandabaer 1st Gen S-series (1983-1994) Tech 1 10-25-2005 02:22 AM
Tags
1988, 1994, 2000, 88, 91, 93, blazer, chev, chevy, computer, ecm, ecu, located, location, s10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
