Engine "Dieseling" - continutes to run after being cut off
Old 08-02-2007, 09:36 PM
BradensCreed's Avatar
BradensCreed is an unknown quantity at this point
Default Engine "Dieseling" - continutes to run after being cut off
what are the most common reasons my 84 2.8 v6 carb motor would do this? let it warm up and idle for a while, cut it off and it chugs and sputters till it dies, usually about 5 seconds. hitting the gas makes it almost rev then die. has been sitting for six months. got it from a guy for a good price... if i can diagnose this.
Old 08-14-2007, 08:58 PM
joseph296 is an unknown quantity at this point
Default RE: Engine "Dieseling" - continutes to run after being cut off
i jsut solved this problem in my 94 v6 it was flooding due to a bad fuel preasure regulator
Old 08-15-2007, 06:46 PM
drperry's Avatar
Totally unrelated to his engine... There is no pressure regulator...
The carb could need rebuilding, or if your lucky just some tuning.
Old 08-15-2007, 07:44 PM
I made a pretty thorough post on engine run-on a while back... Here ya go --> CLICK HERE
Old 08-24-2007, 11:24 PM
not bad. got a can of sea foam and checking the timing as soon as i can. def needs a good tune up so thats going to happen regardless. quick question... what are the benifits of using sea foam in your oil as well as in the gas?
Old 08-25-2007, 03:22 PM
Seafoam in the oil is to clean out any deposits in your engine oil system. It should only be run for 250 miles MAX. In the gas it acts as a fuel injector cleaner, but there are better alternatives for fuel injector cleaners.
dbarrowjr
01-14-2014 05:53 AM
fireman846
01-14-2011 09:31 AM
sedatedbylife
Engine & Internal
02-27-2010 10:54 AM
2000_BlzrLT
03-23-2008 07:27 PM
rewj
12-19-2007 07:43 AM
Quick Reply: Engine "Dieseling" - continutes to run after being cut off
