engine id
engine id
I have an 2.8 v6 engine out of an s10. I need a manual flywheel for this engine. I am trying to find out the year. Here are the numbers off the block.
Right side; canada 14089818 GM 2.8LG
left side; 818 L1
top by dist; GM K2
Rear of block behind flywheel; R 6 818
It has a 2 bbl carb and the belt is serpenteen and vee belt also.
Is the R on the block same as the R for the vin code? Which would make it an '86? But the 2bbl carb? I'm looking at the engine and scratching my head. any thoughts.
Thanks,Kirk
left side; 818 L1
top by dist; GM K2
Thanks,Kirk
RE: engine id
You the same guy asking the same question over on s10forum?
RE: engine id
Yea, It's me. I'm just trying to figure out which flywheel to buy. From what I see online one flywheel is for '85 and down and the other one is for '86 and up. Is there a differents? Does it matter? I want to make sure I get the right one.
RE: engine id
if I had the VIN number from the truck it came out of I could tell you.
RE: engine id
Oh By the way VIN code R goes from 1986 to 1993
RE: engine id
According to my sources...2.8L throttle bottle began in 1986. Serpentine belt began in 1987.
I would say someone has rebuilt or redone this engine before but I am guessing. Like you I am head scratching.
RE: engine id
I don't have the truck so I don't have any access to the vin #s. I know the TBI came out in 86 and I don't see any good reason to go back to a 2bbl carb. I'm thinking it is an 85. I have pulled the flexplate and will head down to the bone yard and try to match it up. I guess I should look for the same year. Someone had mentioned about flywheel/flexplate weights?? something about internal/external weights to balance the engine?? I'm still puzzled by the R stamp on the block. I would think in would be a B.
N.alaska_blazer
02-23-2009 01:31 PM
Tony H
12-14-2008 02:04 AM
loppy crimp
09-11-2008 08:31 PM
DBlaser_ca
08-02-2007 04:44 PM
