Engine Swap
Old 02-16-2009, 10:32 PM
lakeblazer91's Avatar
lakeblazer91 is an unknown quantity at this point
Default Engine Swap
Can i put a 93cpi engine in place of my 91tbi engine if i swap the intake manifolds so the electronicsare the same or is it way more complicated or are the heads/block completely different?
Old 02-17-2009, 03:37 PM
94.Blazer is an unknown quantity at this point
Default RE: Engine Swap
its waaaaaaaaaay more compilcated than just that. the cpi requres an upgraded ECU, and with the upgraded ECU , you'll have to rewire basically everything in the truck, becuse i'm sure that the wires aren' t the same. so if you decide to do it. good luck!
Old 02-18-2009, 02:06 AM
quik1964's Avatar
quik1964 is an unknown quantity at this point
if you decide to swap, a good place to get your wiring is Painless Performance
Old 02-18-2009, 10:09 AM
ok well the guy at the machine shop said he can change heads to make it work with my TBI unit and factor ECM with wiring. So for 700 dollars i hope so.
SureShooter29
03-18-2010 03:02 PM
gmoney30
01-22-2010 07:07 PM
ronnyrum1
Engine & Internal
12-11-2005 11:34 AM
billybird
07-20-2005 11:17 AM
Quick Reply: Engine Swap
