Flickering lights - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 03-12-2007, 02:20 AM
USMaverick101 is an unknown quantity at this point
Default Flickering lights
Hey everyone,
I dunno if anyone is having or has ever had this problem, but recently I've noticed that my lights (headlights, dash, maplights,) are flickering. Not a whole lot,..very slightly, but i notice it. Mostly when I'm stopped at a light in idle. Its not a strong flicker, you kinda gotta focus on it to notice, but it is happening. I have good voltage at 14, and I dont really think its my alternator. It starts right up and stays charged. I dont think it's the battery because I just replaced it last August. Some feedback would be much appreciated.
Kas
Old 03-27-2007, 01:32 PM
anjfisher is an unknown quantity at this point
Default RE: Flickering lights
I have the same issues with my 2000 Chevy Blazer!!! Would like to know what up as well!
Old 03-27-2007, 01:59 PM
johnny_5 is an unknown quantity at this point
hi"... my 01' blazer did the flickering day after i got it home. and just kept getting worse, as i did not have time to get it looked at. now, 2yrs. later, im having to replace the PCM,(250.00) i highly recommend you take time and get it looked at by a dealer, before this happens to you. they say it was the PCM all along, luckily it went out in my driveway, not 50 miles out in B.F.E.. i hope this helps...
johnny5
Old 03-27-2007, 02:40 PM
PCM?
Old 03-27-2007, 11:28 PM
Powertrain Control Module, located on pasenger side(under hood) mounted atop the coolant reservoir
Old 03-27-2007, 11:48 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
First thing to check for is the sound system.Second thing to check is the A/c compressor. At night when my compressor turns on and off,I can tell. Third thing to check isapattern with therpms. if it does it sporadically,I don't know whatit is. I have never had that problemmyself, but I have worked in a shop long enough to have worked ona pcm module. Check voltage from the headlight fuse to negative battery post, play with the throttle a bit until it does it USE an analog meter... digital meters will not show the change as quick.
Old 03-28-2007, 08:45 AM
sory euro, i disagree, neither the radio or AC unit has to do with it. the Powertrain Control Module does. on the OBDII code scanner, the code came up as P1637 altenator L terminal circuit, which controls the ign. and lights, along with many other things. (finding this out as i go) will post more as i collect data
Old 03-28-2007, 08:55 AM
When using the defrost modes the A/C compressor will kick on and off, and the RPM will drop slightly for a brief period of time, sometimes making the lights dim... Heck, the volt meter twitches when the signal lights are on...
If it ONLY does it at idle, then that's most likely the issue, unless your throwing codes...
Try it with the heater system off, or turned to foot or face air blow only, no defrost or A/C, if it still does it, it's not the A/C cycling...
Closed Thread
Thread Thread Starter Forum Replies Last Post
lights flickering after HO install ali1 Lighting & Electrical 12 05-23-2010 02:47 PM
all my lights are flickering RIFLEMAN 308 2nd Gen S-series (1995-2005) Tech 4 02-08-2010 10:48 PM
Flickering interior lights (Updated) Numba1Sean 2nd Gen S-series (1995-2005) Tech 17 11-16-2008 07:59 PM
lights STILL flickering mikeinwi 2nd Gen S-series (1995-2005) Tech 6 06-14-2008 09:12 PM
lights flickering? mikeinwi 2nd Gen S-series (1995-2005) Tech 6 05-11-2008 08:41 PM
Tags
1994, 2000, 94, blazer, chevy, flicker, flickering, focus, headlight, headlights, lights, pcm, rough, running, s10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
