Flywheel cracked?
Old 10-04-2014, 08:33 PM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Default Flywheel cracked?
I searched the forums, but have not found a solid answer because the thread is closed with no solution? I found this video on YouTube and this is EXACTLY what my truck is doing now. Sounds like the valve train, and you would swear by it, but when you get down to the torque converter......
Any ideas? Cracked flywheel?
Old 10-05-2014, 09:31 AM
rexazz2's Avatar
I had it happen on a 305
Starter began giving me issues with engagement
The flywheel had cracked all the way around the crank bolts and then started spidering out towards the teeth
If you unbolt the torque converter it may move away from the flywheel enough to get a better look or you may be able to move the outer edge of the ring gear
Old 10-05-2014, 09:33 AM
rexazz2's Avatar
looks like you already replaced the starter
Old 10-05-2014, 09:38 AM
rexazz2's Avatar
by reading the comments on this looks like the guys bolts were missing or loose
Old 10-05-2014, 10:55 AM
newguy's Avatar
Not even connected
Old 10-05-2014, 02:19 PM
NCSurvival's Avatar
This isn't my truck. It's a video someone posted on YouTube that has the EXACT same problem as I have. But I have a heavy duty starter that works fine.
Old 10-05-2014, 02:44 PM
rexazz2's Avatar
I had no noise
it was the starter issue that brought forward the issue
Old 10-05-2014, 02:46 PM
rexazz2's Avatar
Originally Posted by newguy
Not even connected
not the torque converter , the crank bolts
looks like that one had a fresh motor
Old 10-08-2014, 09:44 PM
NCSurvival's Avatar
Turns out a valve was very loose. And the noise carried down the back of the motor to the torque converter. She’s sounding awesome again.
LowLife
04-14-2010 05:27 PM
thisclan3
06-30-2009 09:00 AM
jonesjamesw
03-28-2008 06:33 PM
tom1337
11-10-2007 12:18 PM
mars004
01-22-2007 10:00 AM
Quick Reply: Flywheel cracked?
