Fuel Pump Relay
Old 10-17-2015, 01:52 PM
90 dB's Avatar
90 dB is on a distinguished road
Default Fuel Pump Relay
Hello all. New here.
I have a 1990 S10 Blazer with the 4.3. It was running fine, then sat for a week, and will turn over but not start. Checked spark - OK. Tried fuel down carb, no joy. I suspect (and actually hope for) the relay. I wanted to jusr replace it, but I can't figure out how to disconnect it from the harness plug! Duhhh.....
There is a sort of latch on the side, but it will not release the darned thing.
Any help?
Thanks,
Bob
Old 10-17-2015, 01:58 PM
If it didn't start when you added fuel, the problem is not fuel related. Better check for a good, hot, blue, not orange, spark at each spark plug.
Old 10-17-2015, 02:07 PM
90 dB's Avatar
Hmmm. I just had the distributer cap/rotor and wires replaced, and it was running fine. Maybe I got a bad cap? Didn't think of that - I've got them before. Thanks!
Old 10-17-2015, 02:20 PM
Check for spark at the coil, at the coil wire where it connects to the distributor, and at each spark plug. Gotta be a blue spark, and it needs to jump a half inch gap to ground.
Old 10-17-2015, 02:22 PM
90 dB's Avatar
I've never actually done that, but I'll try it. Thanks.
Old 10-17-2015, 02:24 PM
Battery needs to be fully charged
Old 10-17-2015, 02:28 PM
90 dB's Avatar
Will do. Thanks again. Glad I found this forum!
Tony H
04-16-2014 08:36 PM
upblazer95
03-08-2009 07:15 PM
bestes
05-31-2008 03:16 PM
Lckyctch
12-30-2007 05:38 PM
mytruck2
12-13-2006 04:50 PM
Quick Reply: Fuel Pump Relay
