Gas leak need help
Gas leak need help
ok guys have 1990 2 dr blazer just put my fuel pump in replace lines with rubber all the way up to the filter problem is when she is running the gas is pissing out were the lines go up in to the frame rail near the front left tire and cant get in there to see what one is cracked im pretty sure its not the return line the was its pissing out
Return line has little pressure. If the truck runs fine it probably is the return. I would figure out which one is the return and replace it with rubber fuel line. Dont have to replace the whole thing, just a section
Not on his tbi engine. us with the 92+cpi,or vortecs (96+) has these. just not tbi. they have 2 big lines with big nut fittings.
op i believe the passenger side one is the return. Dont bypass this line,you can bypass some of it to get past the leak,then plum it,but dont delete the return.
NYCJUDGE
08-28-2011 04:35 PM
starandrose
09-22-2010 06:25 PM
degaine_designs
08-19-2009 11:12 PM
SnowRemorse
01-04-2008 11:26 AM
