Headlight connection corrosion - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 12-18-2011, 11:07 AM
richphotos's Avatar
Default Headlight connection corrosion
I had to get a new headlight for my 93 jimmy, put the light in. it works, but the high beam doesnt. before the old headlight went out, the high on it worked, so Im pretty sure its corrosion and it just corroded while the other headlight was in keeping its connection. Is there a good way to clean these? I do not want to have to get a new connector.
Old 12-18-2011, 03:25 PM
richphotos's Avatar
*edit*
Old 12-18-2011, 03:34 PM
xgiovannix12's Avatar
xgiovannix12 will become famous soon enough
Id use electrical grease on them they will never corrode for a while
Old 12-18-2011, 03:46 PM
richphotos's Avatar
Good idea, living in MN, i should probably do that. Thanks!
Old 12-18-2011, 03:49 PM
radiokid's Avatar
radiokid is on a distinguished road
Thread shouldn't be deleted, this is good advice for any one else having the same issue.
I am glad you got it working again, and for future reference dielectric grease on all electrical connections will assure that moisture stays out, and connections maintain there conductivity.
Old 12-18-2011, 04:21 PM
richphotos's Avatar
Yeah, I have in every socket where I am able to replace just the bulb, going to run to the part store now and get some for the headlight connectors.
Thanks again for the tip.
Old 12-18-2011, 06:34 PM
This is even more important if the connection was already corroded. The contacts are plated to protect them from the factory, but once that plating is gone, there is nothing to keep the copper contact from corroding. Using dielectric grease from here on out will protect the contact from here on out.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Oil Filter Housing Adapter Aluminum Galvanic Corrosion sledzepplin 2nd Gen S-series (1995-2005) Tech 0 08-15-2015 10:13 PM
tccm corrosion...again warthogdriver Lighting & Electrical 6 06-28-2012 04:52 PM
4x4 tccm corrosion causing whining from front differential ziggy888 2nd Gen S-series (1995-2005) Tech 1 09-05-2010 09:50 AM
Lower Intake Corrosion Repair vortexflow Engine & Transmission 0 11-28-2009 01:34 AM
MAF corrosion fix ABN31B 2nd Gen S-series (1995-2005) Tech 5 05-08-2009 07:46 AM
Tags
blaizer, clean, cleaning, connection, connector, corroded, corroision, corrosin, corrosion, corrosive, electrical, head, headlight, headlights, light
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
