Help, Code 15 driving me nuts!
Change the intake gaskets, found the CTS broken and changed it (didnt have code 15 before). Put the motor back together, ran smooth for about 10 seconds, then rough and shaky. Checked codes, got 15 and 43. Changed CTS and code 15 cleared. Finished setting the timing from having engine al apart, unplugged battery again for a few minutes. Plugged everything back up, code 15 is back and its running pretty rough.
HELP!!!
HELP!!!
Ok, got code 15 to clear. Cant et rid of the 43. Tested voltage on the lead with the key on, engine off, it was only 3.6 volts. Tested resistance of KS, nothing. It read 1 the whole time. Where should I start??? Links to any helpful posts are appreciated too. Ive searched till im cross eyed!
thereverendbill
05-28-2010 07:26 PM
mrafindley
12-18-2008 10:41 AM
Dusk4Ever
12-07-2008 11:00 AM
