HELP stuck in 4 wheel drive LOW
Old 03-22-2012, 10:13 PM
bachevy94's Avatar
bachevy94 is on a distinguished road
Exclamation HELP stuck in 4 wheel drive LOW
Ok I have tried everything I can think of and my buddies. Even looked on youtube, ask . com, and so on I can not get it out of 4 wheel lo. Where is the TCCM Fuse everyone is saying to change or unplug?
I need this fixed I have used all my vacation time and have work on monday!!!!!!!!!!!
Old 03-22-2012, 10:33 PM
RetroBlazer's Avatar
RetroBlazer will become famous soon enough
I believe there are two 10 amp fuses that are near the fuse box but separate from the box, one of them should be the TCCM fuse.
I don't have an electronic shift 4x4, but I do have a Bravada service manual as well as an interior wiring harness from an electric shift 4x4 Blazer that I will look at later.
Old 03-24-2012, 06:17 PM
ohsofly's Avatar
Get underneath, and unhook the linkage on your Tcase and switch it manually with your hand. Not a fix, but it will get you going again.
Old 03-26-2012, 02:13 PM
bachevy94's Avatar
I tried the fuse and nothing still in 4 wheel low.
Old 03-26-2012, 02:14 PM
bachevy94's Avatar
I have vacumn lines and electrical it doesn't work like that. It is the first year they came out with the electrical switch
Old 03-27-2012, 12:35 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Here's the non-troubleshooting fix: remove the front driveshaft from the output yoke of the transfer case. Remove the transfer case shift motor (encoder motor) from the side of the transfer case. Manually shift the transfer case back into 2HI. You may have a bad encoder motor. That was the problem with my wife's '93 Jimmy.
If you search through the forums here you will probably be able to find a good set of guidelines for troubleshooting the encoder motor. Hopefully you'll be able to get the rig back on the road soon.
Old 03-27-2012, 10:08 AM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
You can try resetting the encoder motor that is located on the transfer case. Get under the truck and look for a plug on the drivers side of the transfer case, it is up behind a vacuum switch that has 3 lines running to it. Pop the top off the plug and unscrew the bolt/screw on the plug and pull it and then turn the truck on and off and get it to reset. Sometimes even pulling the ground off the battery will reset it as well but like stated it is probably going to keep failing like everything else on this truck does and it will probably need to be replaced. You could also have a vacuum leak somewhere as well, rent a vacuum tester from autozone and see what you find when checking the lines running from the back of the intake plenum. If the line running to the transfer case is not holding vacuum reset the encoder motor, or just reset the encoder motor and then look for vacuum leaks.
Old 04-06-2012, 07:33 AM
Meganutter's Avatar
Meganutter is on a distinguished road
If you have an electrical shift you can pull the TCCM codes by linking the A and J terminal of your ECM connector and then turning on the contact.
Then the indicator lights will flash in a certain patter, i believe its:
long
1, 2, 3, or 4 times depending on the code.
pause
repeat
With code 3 i managed to fix it by resetting the TCCM module, pull the 10 Amp fuse for 5 minutes, put it back in and then (if i also remember correct) turn the contact on/off 5 times.
Good luck.
mirrorimij
06-08-2019 03:34 PM
Al3x
03-07-2010 09:49 PM
huskerinaz
01-19-2008 10:53 AM
marc.doucette
09-30-2007 08:24 PM
dcblazer
12-18-2006 06:07 AM
Quick Reply: HELP stuck in 4 wheel drive LOW
