Help! Vacuum line mess
Vacuum lines should be (4WD CPI):
back of manifold---short pc of hose---"Y" connector (extra fitting is purge canister vac line)---short pc of hose---check valve with four outlets (1. vac ball, 2. heater ctrls, 3. cruise ctrl, 4. xfer case 3 way valve)
make sure there is a hose coming from the top of the purge canister is connected to the front of the intake.
if you could get me pics that would help out alot man and i think thats whats missing, the piece from the intake into a Y. my check valve only has 3? the front line is connected.
ill look further into the rest as soon as it gets back from the shop, i had a terrible noise coming from the front of the engine, the tensioner pulley's bad and apparently when they did just their basic diagnostic it was running way too cool. so waiting to get it back monday.
Update: i replaced/re-ran some lines and replaced the check valve with a new one of the one thats in the pics. but i have no vents, any suggestions? is there a different kind of check valve? someone said something about a 4-port valve but i could only find one like the one in my pics
here is the 4 way chk valve on Amazon.
intoodeep95
17
11-09-2012 08:53 AM
