Window Release
Old 10-25-2007, 06:39 PM
Blazer94's Avatar
Blazer94 is an unknown quantity at this point
Default Window Release
I just bought a brand new 1994 Blazer, and basically the only problem is the back window release. When I hit the button, I hear a noise that sounds like a latch, but when I go back to open the window it is still locked. Is there a way to fix this?
Old 10-25-2007, 07:17 PM
thegr81's Avatar
Default RE: Window Release
it doesn't automatically open up mine does that to were you have to press the button and open it at the same time the interior button is for when someone is back there to open it unless its supposed to pop open when you press it i believe thats how they are
Old 10-25-2007, 07:21 PM
Blazer94's Avatar
Okay, thanks a lot. I'm still a Blazer noob, so I'm not 100% on everything.
Old 10-25-2007, 07:26 PM
thegr81's Avatar
no problem anytime you need help just ask
Old 10-25-2007, 09:07 PM
No gr8, this is NOT how it is supposed to be... When you push the button, it is supposed to 'pop' the latch at the rear window, atleast that is how it is supposed to work in your year... With the '94 it may just unlock the window to where you would still have to turn the latch to release it.
Sounds like there is a problem with the latch or the solenoid inside the rear gate. Can you get the window open? If so, you'll need to pull the interior trim panel and check out what is going on inside the gate with the latch.
Old 10-25-2007, 09:35 PM
thegr81's Avatar
ok kyle, didn't know mine just makes the unlock sound it doesn't pop open i have to press the button and lift at the same time. so you think its a solonoid problem???
Old 10-29-2007, 07:29 PM
Blazer94's Avatar
Yeah, I just sprayed some WD-40 on it. Now it pops open.Hopefully that will work for awhile.
ejwilson1984
04-11-2012 09:46 AM
kymatt
08-27-2010 08:47 PM
dieseldave_2002
09-27-2008 02:27 PM
Hanr3
01-22-2007 02:30 AM
scoot
02-24-2005 09:34 PM
Quick Reply: Window Release
