hood jammed shut - Blazer Forum - Chevy Blazer Forums
Search
Search
Reply
LinkBack Thread Tools Search this Thread
Old 09-24-2012, 05:59 PM
cadaver666 is an unknown quantity at this point
Default hood jammed shut
alright long story short, my hood is jammed on my 94 s-10 blazer. the latch hook is most likely bent, it was bent one morning. I attempted to straighten it out but to no avail. so instead of removing and replacing it i just slammed the hood shut. not its stuck and my powersteering pump is squeeking, and ideas on how to get this hood open to replace the latch I bent?
Old 09-24-2012, 06:25 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
look under the hood,near the latch. you'll see a little metal loop. push it to the right with a screwdriver. hood should pop open,even with the latch bent,it may not open all the way though. once you get to that point just get mean with it......maybe....a sawzall...
Reply
Thread Thread Starter Forum Replies Last Post
Brake Pedal jammed ! Cheveevarer 2nd Gen S-series (1995-2005) Tech 9 09-06-2010 06:16 AM
Jammed 6 disc changer Ares88EP 2nd Gen S-series (1995-2005) Tech 1 04-29-2009 12:43 PM
driverside door lock jammed???? jsides 2nd Gen S-series (1995-2005) Tech 1 09-22-2008 11:06 AM
Jammed Door Key Lock flyinbrad 2nd Gen S-series (1995-2005) Tech 5 12-31-2006 12:18 AM
Jammed Rear tailgate/window mwjungaz General Tech Help 1 08-24-2006 10:10 PM
Tags
1995, blazer, chevy, hood, jammed, keys, locked, open, pop, shut, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
