How to disable ABS, also clicking sound at pedal?
Old 03-03-2010, 03:25 PM
bl95vrtc's Avatar
bl95vrtc is on a distinguished road
sure can, just jump terminals A & H on your ALDL terminal.
any garage will have a capable scan tool for that. there are threads on here already for how to do this.
i unplugged my main ABS plug on the module under the hood, and never had any issues with it.. drove it for over 5 years like that.
i still say it's your ABS motor that's faulty rastoma. we discussed this issue in one of your other threads regarding your crazy brake pedal issues. have you had anyone do a thorough diagnosis of the ABS module or system yet?
i'm also having a similiar problem on my 95 blazer 2wd with the caliper engaging and causing the steering wheel to tug right or left, if I push down firmly on the brake pedal it will disingage. abs light on while its happening. this all started after I replaced the rotors, pads, inner and outer wheels bearings. I would like to just disable the darn abs system. I'm getting a series of codes off of my scanner, 41,42,45,46,51,52,65 and 67. bleh! which of the 3 harnesses on the abs module do I disconnect??
Old 03-03-2010, 11:06 PM
old skool luvr's Avatar
it's been a long time since i yanked the plug on my '92-which i believe is a different system than your '95. anyways, if i remember correctly (99.9999% sure) it was the outside plug. the one closest to the fender.
just remember to smear the plug & terminal with a generous a mount of white lithium grease, to prevent any corossion from happening (in case you ever want to reconnect the system in the future).
Old 03-04-2010, 08:34 AM
rastoma's Avatar
rastoma is on a distinguished road
What are the other electrical connections going to the ABS for?
I just unplugged every electrical connector I saw on the ABS module.
Charder
02-05-2014 02:06 PM
GloryImSaved
07-16-2009 12:50 AM
awmiscool
Headers, Intake, & Exhaust
13
06-09-2009 01:21 AM
JonSDSU
12-04-2007 10:12 PM
apekim
09-15-2007 10:46 AM
Quick Reply: How to disable ABS, also clicking sound at pedal?
