How many O2 sensors do I have? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 02-10-2009, 04:57 PM
s10machine is an unknown quantity at this point
Default How many O2 sensors do I have?
Working on my 91 s10 Blazer, 4.3 4x4. Looking at Advance Auto's web site, they say I have two, an upstream and downstream.Downstream waseasy to get, down on the Y pipe. I assumed I could see the upstream sensor, in the manifold. When I went to remove it, I realized I had the wrong one, I think it is the coolant temp sensor over there, on the passengerside.
Sonow I'm not sure there is a secondo2 sensor, Haynes and Chilton only mention the one. So if there is only one, which should I put in there, upstream or downstream? I assume downstream, because it plug fits. But we can all see how fas assuming anything has got me. I appreciate any help you guys have to offer.
Thanks for checking me out.
Old 02-10-2009, 06:22 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
Default RE: How many O2 sensors do I have?
Mine only has one. Crawl under it and look. There will be one for sure just before the cat converter on the right side just behind the right front wheel. It is a single wire. Run your hand along the rest of the exhaust pipe (when cold) all the way to the muffler. I bet you do not find one.
Old 02-10-2009, 06:52 PM
Of course I found that one, it is the one I referred to as 'downstream'. I am trying to determine if there is another o2 sensor on a 4.3 from 91. Thanks tho
Old 02-10-2009, 06:59 PM
rdhack's Avatar
Downstream means AFTER the cat converter. The only one you probably have and found is upstream.
Old 02-10-2009, 09:59 PM
Yep, the sensor you have found which is directly after the "Y" in the y-pipe and before the catalytic converter is the upstream sensor. If you do not have one behind the catalytic converter, then you only have one sensor.
Old 02-10-2009, 10:25 PM
Okay, that is great, I only have one o2 sensor to worry about. Thanks swartlkk
Closed Thread
Thread Thread Starter Forum Replies Last Post
How many oxygen sensors??? melstal 2nd Gen S-series (1995-2005) Tech 7 03-31-2015 05:08 PM
how many wires on the two upstream 02 sensors scphill34 Lighting & Electrical 0 03-31-2013 09:41 PM
How many 02 sensors? 4.3L TBI jeff771 Engine & Transmission 2 04-12-2012 11:37 AM
Oxygen sensors ( How many and where ? ) Supercity Engine & Transmission 6 07-10-2011 01:23 PM
How many O2 Sensors? cjbehrens 2nd Gen S-series (1995-2005) Tech 5 02-28-2009 11:14 PM
Tags
02, 1991, 1998, 43, 89, 99, blazer, chevy, have, location, o2, oxygen, remove, s10, sensor, sensors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
