4WD NOT WORKING BY PUSH BUTTON
HI,I HAVE 1993 S10 BLAZER AND MY 4WD WILL NOT WORK BY PUSHING THE BUTTON I'VE TRIED EVERYTHING IN ALL OF OTHER THREADS AND NOTHING HAS WORKED.SO MY PROBLEM IS 4-WHEEL LOW USE TO WORK BUT THEN IT STUCK IN SO I DISCONNECTED THE VACCUM HOSE TO THE ACCUATOR AND PULLED ONTHE CABLE AND THEN IT WENT BACK TO 2-WHEEL DRIVE.SO I PULLED ON IT AGAIN ITS STILL IN 4HI SO WHAT I'VE BEEN DOING WHEN I DONT NEED IT IS DISCONNECTING THE ACCUATOR HOSE AND PLUGING OFF THE "T" FITTING.I WOULD LIKE TO GET THE BUTTON WORKING AGAIN BEFORE HUNTING SEASON AND WINTER COMING SOON.IF ANYONE CAN HELP ME.THANKS
RE: 4WD NOT WORKING BY PUSH BUTTON
Step #1 - fix your CAPS lock...
When you say it stuck in, did you pick the vehicle off the ground and see if the front driveshaft was still being turned by the transfer case? An engaged front axle does not mean that the transfer case is still engaged. If unhooking the vacuum line caused the system to go into 2HI it sounds like you may have a faulty vacuum switch on the transfer case which may cause the indication of it still being in 4wd, but not result in the front axle actually being powered.
Sorry about the caps lock.No i did not lift front end but very hard to turn kinda like having no power steering but i know power steering is working.and as soon as i disconnect vaccum hose it steers fine.almost for got this done on dry ground.if i replace the transfer case switch "the one onthe t-case with 3 vaccum lines coming out of it" this will be the 3rd time in a year and last one i changed seemed fine but the first one i changed the ball on the in side was stuck.i'm not sure what to do next.thank for help .
tululilopo
27
07-02-2010 12:04 PM
Blazerama
12-12-2008 12:22 PM
