Ideal idle RPM - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 02-12-2011, 04:36 PM
89 Blazer Lebanon's Avatar
89 Blazer Lebanon is on a distinguished road
Default Ideal idle RPM
What's the factory and/or ideal idle RPM for my 4.3 TBI engine? Mine runs at 1.3 - 1.4. Is it normal or too high as I think?
Old 02-12-2011, 05:50 PM
old skool luvr's Avatar
Quote:
1.3 - 1.4 what?
the truck should idle anywhere from 550 RPM to a max of 750/800 for a manual trans'd vehicle.
of course, the engine will idle slightly higher when it's cold (not warmed up).
Old 02-13-2011, 03:22 AM
Quote:
Well, when I start mine it goes up to 2000 RPM or something around for like 20 seconds, then goes down to 1300 - 1400 (down to 1500 - 1600 for a minute or less if it's really cold) and keeps that speed even during summer after driving it for hours. It goes down to 1100 when I put it on D with a little kick.
Old 02-13-2011, 10:23 AM
ok, i kinda thought you meant 1300 RPM, but didn't want to assume.
start checking out your IAC (Idle Air Control) it could be dirty or just plain broke.
be careful though, i had one shoot the plunger out completely once (it was off the truck for cleaning) and it never worked after that.
you'll also want to check your throttle body too. make sure nothing is making the throttle plate stick open. even if it's stuck open just a little, it'll affect your base idle speed.
question. you've been a member for quite awhile now, is this something that has just happened recently?
Old 02-13-2011, 12:52 PM
I had this Blazer for 2 years now. It had a bad fuel pump when I bought and hauled it to a servicing garage where it had a lot of parts changed. It was so since I bought it and thought that this was normal. Last summer, I was revving it very high and got the magnet inside the distributor broken into pieces, so I bought a new one from a scrap-yard and changed it myself, and as I tuned the distributor (turning it L & R), when the RPM was going lower than 1200, the engine would start kind of shaking (as I remember). Before I mess with my IAC, is there a way I can tune the idle speed? I thought it's controlled by the computer!
Old 02-13-2011, 03:09 PM
rriddle3's Avatar
Your idle speed is controlled by the IAC.
Old 02-13-2011, 04:37 PM
Quote:
So how can I change the idle speed? By using a scanner? (which I don't have :P )
Old 02-13-2011, 09:17 PM
rriddle3's Avatar
Clean or replace the IAC and its connection. The 'search' function should help out.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Total Number Of Speakers Running = Ideal Setup ChevyBlazer4uHaters Audio/Video Electronics 20 01-16-2014 01:36 AM
Ideal Running Temp? Little Roober Engine & Transmission 3 05-25-2011 03:15 PM
idle at 3k rpm when start up 95Blaz3r 2nd Gen S-series (1995-2005) Tech 1 03-02-2009 03:00 PM
JUST WILL NOT IDLE UNDER 2000 RPM ???? CRAZY4WHEELER2 2nd Gen S-series (1995-2005) Tech 3 06-30-2008 08:24 AM
idle rpm jdblazer 2nd Gen S-series (1995-2005) Tech 2 12-18-2006 12:24 AM
Tags
1979, 2002, 350, 43, 97, blazer, checy, control, diesel, ideal, idle, normal, rpm, speed, supposed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
