Instrument cluster
Old 03-12-2017, 02:54 PM
Brandon Hagenbuch's Avatar
Brandon Hagenbuch is on a distinguished road
Default Instrument cluster
Hello, im new to this site so idk if there is already a thread about this but I'm looking for a new analog instrument cluster for my 91 s10 blazer auto trans. Idk if anyone knows somewhere online I could by 1 but I've only seen the digital ones on eBay and I haven't found a junkyard near me that has one but my main question is can I just replace each gauge separately or do I need to replace the whole thing?
Old 03-13-2017, 09:38 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Old 03-13-2017, 04:56 PM
So everyone changes to digital? Or do they repair analog too? Cause I have an analog cluster. I had a 94 s10 blazer years ago with the digital cluster.
Old 03-14-2017, 03:30 PM
mr.vls's Avatar
mr.vls will become famous soon enough
I have a 89 S15 that I replaced the gages from junkyard clusters. Yes you can replace individual gages. The only caution I have is when you have the replacement gage. The dash cluster removed. The gages are mounted on plastic studs with nuts. It is very easy to overtighten the nuts on the plastic studs and break the stud. The cluster is held in by 4 nuts. 2 behind the light switch and 2 behind the heater switch. You do need to remove the lower dash panel. The clusters just pulls out from the dash. You can also just remove the dash face by removing the screws for the das face and pulling it out from the dash as that is where the gages are mounted. Any S10/s15 truck or blazer will work. There are some differences on the graphics between years.
elementalnature
03-24-2008 05:31 PM
error_401
03-17-2008 06:39 PM
DoubleSprings
09-15-2007 11:20 PM
Russ57
05-14-2007 01:43 AM
FJ40sRock
03-05-2006 04:48 AM
Quick Reply: Instrument cluster
