Intermittent running rough under load and at idle - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 09-18-2010, 08:46 AM
oopackmanoo is on a distinguished road
Default Intermittent running rough under load and at idle
I have a '94 Chevy Blazer Vin W. I have totally rebuilt and replaced almost all sensors and components. These are heater core, distributor, cap, rotor, wires, plugs, ecm, map sensor, tps, egr valve, coolant temp sensor, oxygen sensor, fuel pump, fuel injector, fuel line kit, ac compressor, ac drier, lf window motor, water pump, fan clutch, reman cylinder heads, ignition coil, front and rear brakes and wheel cylinders, new shocks, iac motor, starter, battery, and knock sensor. Some days the vehicle runs fine. Other days it searches for idle and runs rough under load. It kind of makes a popping noise. I have a lot of money invested in this vehicle and I'm hoping someone can help. We first thought it was a fuel problem with the way the truck was acting, but replaced all fuel compents with and put on a new fuel injector. The only thing that I think it could possibly be is the pcm. That's the only component we haven't replaced. Any ideas would greatly be appreciated.
Old 09-19-2010, 03:27 AM
Magmotor's Avatar
Magmotor is on a distinguished road
You didn't mention the cat. If that is plugged, it can cause a lot of problems.
Old 09-20-2010, 02:28 PM
Default The cat has flow
The rough idle and roughness underload are both intermittent. The cat seems to have good flow. Took it off and cleaned it. Maybe it needs replaced. I actually found out that the pcm has been changed. Don't know if I got a faulty one of those or not though. Any other ideas of what to test??
Old 09-20-2010, 04:17 PM
94BlazerPA is on a distinguished road
Its probally the fuel injector connector, that plug that connects onto the top of the Spider inside the plenum. The rubber spacer goes to mush from being exposed to fuel and cause's a loose connection. Theres 2 wires, red and blue that run out the front of the plenum on the driver side. Wiggly them while its idling and see if it acts up. I figure its this, becuase you say underload, so the connector vibrates and causes a poor conection. Its a $10 fix at Autozone.
Old 09-27-2010, 07:23 AM
Thumbs up Problem solved
After more careful inspection, I got the bright idea of unplugging the egr to see what would happen. Idle smoothed out and could rev engine with no hesitation. There is a three way check valve on the back of the intake. When I inspected it, I noticed a small crack that was allowing the intake to get too much air. It was intermittent b/c when it was turned one way the crack closed and the other opened the crack. Replaced the three way valve and the truck is running like new. Thank you to the people who helped me narrow it down. I just wanted to post the fix in case anyone else runs into the same problem.:icon_raz z:
Old 09-27-2010, 09:33 AM
ohsofly's Avatar
Quote:
x2 - That part is my friggin nightmare. My fix was to solder on a new connector, then before putting it on the injector I put 2 of the tiniest Orings on the pins, then press the connector on and its tight as all hell now. Its a whole $8.00 and the dude will give you 4 of the tiniest rubber rings hes got. You need the ones that stretch a little over the pins on the injector.
Closed Thread
Thread Thread Starter Forum Replies Last Post
rough cold start idle and rough running blazerguy22 2nd Gen S-series (1995-2005) Tech 10 11-14-2013 11:50 PM
Blazer Misses @ idle and bogs under load. Ryan Cornforth 2nd Gen S-series (1995-2005) Tech 16 02-19-2013 01:55 PM
95 blazer missing at idle, under load joshe8695 2nd Gen S-series (1995-2005) Tech 4 02-15-2011 09:44 AM
4.3 Vortec runs rough under load slravenel Engine & Transmission 5 02-02-2010 06:31 PM
Rough running under load bstonian 2nd Gen S-series (1995-2005) Tech 1 06-13-2009 01:27 PM
Tags
1993, 43, 50, blazer, chevy, ford, idle, idles, knock, load, rough, rought, runs, s10, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
