Missing vacuum hose connection
Old 04-07-2014, 07:07 PM
btb1003's Avatar
btb1003 is on a distinguished road
Default Missing vacuum hose connection
1994 S0 Blazer 4x4 4.3 CPI... After changing the plugs I discovered a vac line broken from age that leads to somewhere near the firewall on the passenger side . It heads towards the front along the fenderwell and curves under the battery box to what I believe is a canister. Any ideas on where the broken end connects to? BTW, All hoses at the tee behind the intake are connected. Mileage has dropped to 14 mpg
Old 04-08-2014, 11:32 AM
Skitzoape's Avatar
Skitzoape is on a distinguished road
If its going under the battery, thats where the 4wheel drive vacuum actuator is.
Old 04-09-2014, 07:58 AM
btb1003's Avatar
Any idea where the opposite end connects?
Old 04-09-2014, 08:28 AM
EZEARL's Avatar
EZEARL is on a distinguished road
If it's the one to the actuator the other end connects to the vacuum switch on the transfer case.
Old 04-09-2014, 11:08 PM
TheRemedy's Avatar
TheRemedy is an unknown quantity at this point
If it's the 4wd line, it will follow the transmission dipstick down to the transfer case top. It can be a challenge to get to, but you should be able to trace it back from the switch by feel.
DeafTimberWolf
06-07-2018 05:01 PM
chcknugget
03-04-2013 06:45 AM
TimAH
09-14-2011 04:26 PM
4thgenceli
02-27-2011 02:07 PM
mohawks76
Performance & Brainstorming
05-24-2008 09:42 PM
Quick Reply: Missing vacuum hose connection
