My 94 won't go into 4WD - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 01-28-2009, 03:54 PM
jeffnews is an unknown quantity at this point
Default My 94 won't go into 4WD
Hoping someone might be able to help me. I have a 94 S10 Blazer and it has push button 4WD and it won't change to 4WD. I replaced the push button and still nothing. I think the Four Wheel Drive Actuator may have gone out. Does anyone know how to test it and where is it located? Any other tips would be appreciated as well. Thanks in advance
Old 01-28-2009, 04:42 PM
livlifes2short is an unknown quantity at this point
Default RE: My 94 won't go into 4WD
does the switch even light up? do you hear any noise? Are you in park netural drive??
Old 01-28-2009, 05:23 PM
Yes the switch lights up. I tried in Park and Netural. There is no noise at all.
Old 01-28-2009, 07:24 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
the actuator is directly under the battery in your 94 as far as testing, first off have someone else start it and hit the 4hi button while you watch the actuator if it appears to be pulling the cable turn the truck off and pull the cable by hand and clamp vice grips on it then try to turn the front driveshaft by hand if it wont turn you found the problem. before replacing the actuator closely inspect your vac hoses when 4wd in my 94 quit last winter it was as simple as a new vac line (I replaced every vac line i could find while i was at it but thats your call i just didnt want anymore vac probs in the near future)
Old 01-28-2009, 07:50 PM
ok so the actuator is vac controlled I did not know that. I do have a vac leak that i've been trying to hunt down that may be the the problem. Thanks for the advice
Old 01-29-2009, 09:33 AM
Default RE: My 94 wont go into 4WD
Yeah, fix any and all vacuum leaks first and then let us know if you need further assistance.
Old 02-02-2009, 05:58 PM
mandng0 is an unknown quantity at this point
PM Sent
Old 02-03-2009, 12:34 AM
Is it me or does it seem when you get one thing fixed something else goes wrong? It now shifts into 4-wheel drive (I think I replaced every vacuum line I could see) but now the transmission is slipping. Will the Trans out of an 89 fit? Is the Trans the same for the CPI and the TBI? I have an 89 that I’ve been using as a parts truck and it has a good tranny but it’s a TBI.
Old 02-03-2009, 11:50 PM
blazer934x4 is an unknown quantity at this point
if the motor is the same first dran the tran thats is slippin and add bottle lucas trans add fill with new fl and test drive ifit doesn't work just put the fluid in the other trans u want loose any money just a little time
Closed Thread
Thread Thread Starter Forum Replies Last Post
98 blazer wont go into 4hi but will go into 4lo ? poepoe624 2nd Gen S-series (1995-2005) Tech 2 01-10-2010 12:48 PM
01 blazer won't shift into 3rd gear Cornhusker Engine & Transmission 4 11-01-2009 06:57 PM
Vehicle won't go into 2wd, any idea's? dB Don Engine & Transmission 3 10-22-2009 12:40 AM
95 4x4 won't go into 4hi don69 2nd Gen S-series (1995-2005) Tech 3 12-21-2008 07:09 PM
Will not go into 4 high (now will not go into 2WD) Boiler_81 Steering, Suspension & Drivetrain 4 12-02-2008 11:04 AM
Tags
1994, 4wd, 4wdr, 94, actuator, blazer, blqzer, change, chevy, drive, s10, turn, wheel, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
