my blazer blows no hot or cold air!
Old 08-25-2010, 01:08 PM
sprbld417's Avatar
sprbld417 is on a distinguished road
Default my blazer blows no hot or cold air!
hey guys whats going on. my blazer blows no hot or cold air. what should I check and look at to make at least the hot air work? My thermostat is broken. When thermostats break they usually stay stuck open rather than closed so I'll go out on a limb and say my thermostats stuck open all the time. Would replacing my thermostat make it blow hot air again?
Old 08-25-2010, 01:45 PM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
You should replace your thermostat no matter what, just so that your truck doesnt over heat and cause damage to your engine.
What do you mean by "doesnt blow hot or cold"? Do you feel air coming through your vents? If not, it could be your blower motor. Do you hear the motor running?
You need to give us more info about the problem so we can better troubleshoot it. We cant guess, or we could and give you a whole list of things to try that would be a waste of your time.
Old 08-25-2010, 02:32 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
1. we need year make and model of your truck.
2. how do you know your thermostat is broken?
3. is your blower motor working? (is air moving out of the vents?)
Help us help you.
Old 08-27-2010, 07:08 AM
sprbld417's Avatar
1991 s10 blazer 4x4. 2 door.
I believe my thermostat is broken because nothing displays on my temperature gauge and my rad is stuck on all the time. No air blows out of the vents at all.
Old 08-29-2010, 06:44 PM
Sleazy_E's Avatar
Sleazy_E is on a distinguished road
Blower motor?
Old 08-29-2010, 06:59 PM
94BlazerPA's Avatar
the lack of display could just be a fault temp sensor, not the actual thermostat. When you mean your rad is on all the time, do you mean the FAN? Unless you have an aftermarket electric fan hooked up, you fan will always be ON, due to the fact its connected to your pullies and will ran whenever the truck is running.
Old 08-29-2010, 08:43 PM
bowtie-72's Avatar
bowtie-72 is on a distinguished road
Could be your fan switch on the dash. Check your blower motor first.
FT III
06-29-2015 09:51 PM
stevenhousden
07-06-2014 05:56 PM
j_o_s_h
08-28-2013 02:40 PM
timmi79
02-15-2011 09:01 AM
ravenhurst
15
04-26-2009 07:53 AM
Quick Reply: my blazer blows no hot or cold air!
