Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 1st Gen S-series (1983-1994) Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to Blazer Forum!
Welcome to Blazer Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Blazer Forum today!
Reply
LinkBack Thread Tools Search this Thread
Old 04-14-2011, 12:02 PM
jrodc262 is on a distinguished road
Default Oil Pressure Switch Removal
Hey guys I have a 1988 S10 Blazer 4.3. The oil pressure gauge has been staying at the very top and not moving at all. I'm going to try putting a new oil pressure switch on, but I'm not sure what size socket it takes to get the thing off of there. Any help would be appreciated.
Old 04-14-2011, 07:59 PM
1989 GMC S-15
mr.vls will become famous soon enough
Not sure on the socket size but you could purchase the replacement switch and then you will know the socket size. If this is still the original oil pressure switch the body of the switch is wider than the hex. What this means is that you have to use a wrench to remove as you cannot get a socket on it. The replacement switches have a smaller body for the switch so you can use a deep socket over the body of the switch.
__________________
1989 S15 Jimmy (DD) with 415K Miles, GM Factory Rebuilt Engine/Trans. New Paint, Headliner, New Suspension Bushings, Eddlebrock Waterpump/Shocks, Adj. Fuel Pressure Regulator and in line Fuel Gage, Injector Spacer, K&N Air Filter, Stock Exhaust, Michalin X-Radial Tires (215/70) Stock Rally Rims, Pioneer Head Unit, IPOD Adapter, Pioneer 4X6 Plates in the front, Pioneer 6X9 5 way sp Rear, 8" Clarion enclosed amp & supwoofer, 10 Disk CD Player. ABS Headliner, Original Owner.
Old 04-14-2011, 09:26 PM
Oh ok. It is the original I'm trying to remove. So there's no way a socket will fit over it huh? That sucks haha.
Old 01-13-2013, 03:24 PM
OlBoothBoy is on a distinguished road
i have an 89 with the 4.3 and im not even sure where the switch/sendin unit is.. iif i aint mistakin i believe its right behind my airfilter on the drivers side of my dist. cap can anyone clarify?? i havent done any test but i figured hell it was only 11$ couldnt hurt to replace it because my gage fluctuates itll idle at like 30 after its warm everynow and then itll jump up to80+ psi. followed by a shutter. so any advice on where its out and how in the hell i can get the thing out? cause if im lookin in the right place it aint gonna be easy.
Old 01-13-2013, 05:40 PM
1989 GMC S-15
It is on the driver side of the distributor. For access you will have to remove the air cleaner and most likely the throttle body bracket on the drivers side of the intake manifold. If this is the original factory switch you will have to use a open end wrench to remove the switch because the switch housing is wider than the hex at the base of the switch. Note: The switch is mounted on an angled adapter that threads into the block. Be carefull not to put sideways pressure on the switch or you will chance breaking off the adapter in the block. I know that this is a concern as I did this and had to remove the broken adapter and than get a new adapter at a "you pull it junkyard".
__________________
Reply
Tags
43, 88, blazer, chevy, extra, gauge, gm, install, location, oil, pressure, removal, s10, sensor, switch, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
