parts compatablity
parts compatablity
ok i have an 88 s10 blazer 4x4 2 dr. my father in law just used most the front clip off a 91 or 92(we dont know the exact year but the door tag has a date of 10/91 on it) 4dr 4x4 that hes gunna let me raid for parts. the parts i want for sure are teh windsheld, front and back seats, drivers side fender and both front doors. i know there were a few cosmetic changes in the first gen blazers but would all that fit the 2 door blazer?
RE: parts compatablity
A 91 or 92 is also a first gen. Second gen was 95+,
If you look on LMC, you will see if the parts you need will bolt right up as they give year ranges for everything.
I am fairly certain that the back seats will not fit. I cannot remember how they are setup in a 1st gen, but the 2nd gen back seats are quite different.
if my memory is correct, the doors on a 2dr are longer than a 4dr (fronts) be sure b4 you go thru all that work.
in the 1st gens i have had (86,88,91,93 typhoon and my current 94) the back seats are different in 2 and 4dr models 2dr has room for 2 in the back with armrest, zip up storage area and 6x9 speaker on either side but the 4dr rear seat is wider and has room for 3 with a fold down armrest in the center, you may be able to remove the armrest and zipper storage area on the sides to make the 4dr seats work I dont know never tried it myself, also i never measured so I dont know if they bolt down the same or if that is different as well. One more thing, 2dr has a lever on the pass side to fold rear seat down whereas my 4dr has lever in the middle on the back of the seat to fold it down. Just some things to check out before you go through the work of taking them out.
Windshield interchange:
A
BLAZER S10/JIMMY S15 83-92
BRAVADA 91-92
S10/S15/SONOMA 82-92
SYCLONE 91
TYPHOON 92
B
BLAZER S10/JIMMY S15 93-94
BRAVADA 93-94
S10/S15/SONOMA 93
TYPHOON 93
|B| fits |A|; '93 up has solar glass.
Door interchange:
A
BLAZER S10/JIMMY S15 83-93 manual
S10/S15/SONOMA 82-91 manual
S10/S15/SONOMA 92-93 exc. extended cab; manual
S10/S15/SONOMA 92-93 extended cab, manual
B
BLAZER S10/JIMMY S15 83-93 electric
BRAVADA 91-93
S10/S15/SONOMA 82-91 electric
S10/S15/SONOMA 92-93 exc. extended cab; electric
S10/S15/SONOMA 92-93 extended cab, electric
SYCLONE 91
TYPHOON 92-93
C
BLAZER S10/JIMMY S15 94 manual
D
BLAZER S10/JIMMY S15 94 electric
BRAVADA 94
4 Dr. models available '91 up; front doors are the same for the 2 & 4 Dr. models.
|A| thru |D| interchange as shown in notes.
When interchanging '82-85 with '86-93, use original door inner trim panel as template to drill armrest & trim pad attaching holes as required.
Electric windows.
No side door guard beams used.
|A| fits; difference is regulator.
|C| fits; difference is regulator & side door beams.
|D| fits; difference is side door beams.
A
BRAVADA 91-92
SYCLONE 91
TYPHOON 92
B
BRAVADA 93-94
S10/S15/SONOMA 93
TYPHOON 93
Door interchange:
A
B
BRAVADA 91-93
SYCLONE 91
TYPHOON 92-93
C
D
BRAVADA 94
Electric windows.
lionel2
17
02-13-2008 04:23 PM
mrjoeyjiffy
08-13-2005 01:32 AM
