pitman arm on a 94 4x4 blazer - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 06-04-2010, 10:34 AM
ethan.zick is on a distinguished road
Default pitman arm on a 94 4x4 blazer
i need to change my pitman arm any tricks to it?
it apears i neeed to un bolt the steering box because the pitman arm is like 3/4" from the crossmember i cant even fit a wrench to take it off
Old 06-05-2010, 08:43 AM
ohsofly's Avatar
Remove the steering box, there is 3 or 4 large bolts that hold it to the framerail and disconnect the input shaft. You will probably need a pitman arm puller to get it off the steering box splines. Mark where everything was aligned before you take anything apart.
Old 06-10-2010, 01:55 AM
4x4VegasDan is on a distinguished road
Do what ohsofly said above. I did mine on my 84 and it was a little tricky. I used a 33mm socket and breaker bar to get the nut that holds the pitman arm to the steering box and then just put the pitman arm puller on there.
Old 07-29-2010, 10:57 PM
Banned
michaelross is on a distinguished road
I have bought a pitman arm puller online and it really is a great tool. I used to have much difficulty changing the pitman arm but not anymore..
Old 07-30-2010, 08:12 PM
rusty91 is an unknown quantity at this point
it is like everybody says when your done make sure the idler and pitman arm are the same length from the frame to keep your alignment correct
Closed Thread
Thread Thread Starter Forum Replies Last Post
Replacing Pitman arm and Idler arm greatwhite Steering, Suspension & Drivetrain 3 11-29-2010 12:54 AM
Ball joints, tie rod ends, pitman arm, idler arm package 88s10Blazer General Chat 3 12-24-2009 09:43 PM
idler arm/pitman arm install? GMdesigner Steering, Suspension & Drivetrain 3 08-23-2007 05:57 PM
pitman arm, idler arm, what a pain kornphlake 2nd Gen S-series (1995-2005) Tech 10 12-18-2006 03:18 AM
idler arm, pitman arm replacement cost RedOctober General Tech Help 3 10-11-2006 10:00 PM
Tags
1993, 2000, 4x4, 84, arm, blazer, change, chevrolet, chevy, pit, pitman, remove, replacement, s10, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
