positive battery cable - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 12-16-2009, 05:10 PM
mason0517 is on a distinguished road
Default positive battery cable
i have a small lead off the positive battery cable on my 90 s10 blazer where does it bolt to. thanks
Old 12-16-2009, 05:51 PM
neo71665's Avatar
You should have a pretty good sized wire go down to the starter and a smaller one that goes to a stud on the back of the alternator on a stock setup.
Old 12-28-2009, 03:13 AM
Gimpy Blazer is on a distinguished road
If it's what I think you mean, they are called fusible links and actually take the place of a big inline fuse. The wire size is VERY inportant if you have to replace one. Too big and it won't burn through until REALLY overloaded. Too small and you might be replacing it a lot. Do a little research on them. I think the concept is pretty cool. My factory manual tells you how to make one if the part is not available and you need one. Most aftermarket manuals mention them too. Sorry for the delayed response on this. Hope it helps you out. By the way, if one does burn on you, you usually have to look at the underside to tell. Why? One of the mysteries of life I suppose. I don't know.
Old 12-29-2009, 12:34 AM
neo71665's Avatar
On a lot of earlier first gens there is no link in them. My 87 came from the factory without a fuse link.
The smaller lead on a positive battery cable is the charging wire from the alt.
Old 12-29-2009, 03:37 AM
I'm getting senile in my old age. You're right. The fusible link on my 94 Blazer is between the generator (alternator) and the junction block. Shows what you get trying to go from memory (or lack thereof). I believe my 84 Jimmy has one there too, but I'll have to check. You pricked my curiosity. Thanks for keeping me straight.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Melted Wire - Replace 1996 Blazer Positive Battery Cable Nate Chesebro Lighting & Electrical 2 09-27-2012 10:05 PM
Positive Batter Cable Replacement bhisley Lighting & Electrical 2 09-15-2011 09:42 PM
Replacing positive battery cable ?? TAZ454 Lighting & Electrical 5 12-02-2010 08:16 PM
Positive battery cable... blrob5 Full Size K5 Tech 10 09-07-2010 09:57 PM
Positive Battery Cable for 95 s10 Blazer azembdriver 2nd Gen S-series (1995-2005) Tech 1 02-18-2009 07:35 PM
Tags
1994, 2nd, battery, blazer, cable, cables, chevy, fuseable, gear, link, postive, replacement, s10, starts, transmision
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
