rear window(tailgate glass) button?
Old 05-01-2009, 11:50 PM
classklown90's Avatar
classklown90 is on a distinguished road
Default rear window(tailgate glass) button?
what exactly does this do?(i have a 94 blazer) i press it and it sounds like it unlocks it. is that what its for? if so i think the ock is sticking because it still requires the key to open
Old 05-02-2009, 12:47 AM
joeroket's Avatar
joeroket is on a distinguished road
Mine does the same thing because the gate is sprung placing pressure on the glass which puts a load on the latch and the electric solenoid is not powerful enough to overcome the load.
Have someone place a little pressure on the glass while you press the unlatch button. If it unlocks then you probably have an issue of excessive load on the latch.
Old 05-02-2009, 12:54 AM
ok thanks. lol you always answer my questions. thanks for that
Old 05-02-2009, 03:10 AM
joeroket's Avatar
No problem. I have been given help on here and the best repayment is to give it back on here to others.
Old 05-02-2009, 09:07 AM
I will try thanks
Old 10-05-2009, 07:25 PM
boscoedoodle's Avatar
boscoedoodle is on a distinguished road
I'm on my third gen, blazer. A nice 93 4x4. When I would press the latch unlock it sounds as if had unlocked but it didn't. I had to use the key. I removed the access. unbloted the solenoid which pulls the latch, and moved the solenoid away from the original bolt holes about a bolt hole away. viola!
blazen_red_4x4
08-02-2020 03:18 PM
slowpoke
13
07-29-2012 03:44 PM
scosentino88
06-03-2012 07:12 PM
alloy
10-10-2011 01:59 PM
chris015
07-28-2011 01:57 PM
Quick Reply: rear window(tailgate glass) button?
